ObjectARX
Distinguished Contributor
421232206
Message 1 of 3 (226 Views)
Accepted Solution
can not compile ARX's example "BlockView" with OjbectARX2010
226 Views, 2 Replies
12-11-2012 02:18 AM
there is an example called "BlockView" in OjbectARX2008's SDK. it is in the directory "ObjectARX 2008\samples\graphics\BlockView",
 it can be compiled and worked well.
but in ARX2010,i can't find this example, and when I tried to compile it with ARX2010 in VS2008, there were errors :
error C2259: 'OrbitGadget' : cannot instantiate abstract class
error C3248: 'AcGiDrawable::worldDraw': function declared as 'sealed' cannot be overridden by 'OrbitGadget::worldDraw'
can anyone help me solve this problem?
it seems that OjbectARX2010 dose not want users to inherit from class AcGiDrawable, but ARX2008 supports this.
Technology change life! Programing change technology!
Valued Mentor
owenwengerd
Message 2 of 3 (224 Views)
Re: can not compile ARX's example "BlockView" with OjbectARX2010
12-11-2012 02:39 AM in reply to: 421232206
You'll need to update the code for ObjectARX 2010, but it should work fine once it is updated. It may help to review changes listed in the ObjectARX 2010 migration guide (docs\arxmg.chm).
Owen Wengerd
ManuSoft
421232206
Message 3 of 3 (211 Views)
12-11-2012 07:41 AM in reply to: owenwengerd
thanks a lot, i have solved the problem with your advice. the chm helps.
thank you again.
the way is to replace the methods with sub<Old method name> methods provided.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
