ObjectARX
bug about acedssget when the name of layer contains "#"
1 REPLY 1
468 Views, 1 Reply
I have a dwg with a layer called "2-1#", and there are some inserts on this layer.
there are two layers on this dwg, and I just want to select inserts on layer "2-1#" ,so I tested the following code:
resbuf* rd = ads_buildlist(RTDXF0,_T("insert"),8,_T("2-1#"),0);
            ads_name ssName;
            acedSSGet(_T("X"),NULL,NULL,rd,ssName);
            ads_relrb(rd);rd = NULL;
            long lNumber = 0;
            ads_sslength(ssName,&lNumber);
            acutPrintf(_T("\n%d"),lNumber);
            ads_ssfree(ssName);
 execute the code ,and selected none.  but then I change the layer name to "2-1", and the code to "ads_buildlist(RTDXF0,_T("insert"),8,_T("2-1"),0);", this works.
so , i guess the problem is about char "#",  but how to solve this.  I tested my code on AutoCAD 2008.  there is a dwg attached.
1 REPLY 1
owenwengerd
You must escape wildcard characters with a reverse quote character: `#.
Owen Wengerd
ManuSoft
”Boost
