ObjectARX
Active Member
dshKSS
Message 1 of 6 (236 Views)
Transparency not working in 64 bit
236 Views, 5 Replies
09-11-2013 02:07 AM
The following code is an example of how I am calling transparency on a custom entity.
For some reason it works in 32 bit but not in 64 bit autocad.
Any ideas?
double setTransAlpha = 40;
AcCmTransparency trans(setTransAlpha);
trans.setMethod(AcCmTransparency::transparencyMethod::kByAlpha);
if(transparency == 0)
       setTransAlpha = 255;
else
setTransAlpha = 255 - ((255.0/100.0) * transparency);
trans.setAlpha(setTransAlpha);
mode->subEntityTraits().setTransparency(trans);
Moderator
Alexander.Rivilis
Message 2 of 6 (217 Views)
Re: Transparency not working in 64 bit
09-11-2013 07:18 AM in reply to: dshKSS
What version of AutoCAD and ObjectARX are you using?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Distinguished Mentor
owenwengerd
Message 3 of 6 (216 Views)
09-11-2013 07:19 AM in reply to: dshKSS
You'll need to provide more information than "it doesn't work". Does AutoCAD crash? If so, what is the exception?
Owen Wengerd
ManuSoft
Active Member
dshKSS
Message 4 of 6 (209 Views)
09-11-2013 07:29 AM in reply to: dshKSS
I am using AutoCAD 2013 and ObjectArx 2013.
Not working means it's not working. In 32 bit the custom object is transparent. In 64 bit it isn't. No crash, no exception, no error messages. It carrys on as normal except the entity is not transparent.
The code is exactly the same.
Contributor ow
ow
Message 5 of 6 (180 Views)
09-15-2013 04:25 AM in reply to: dshKSS
And the system variable TRANSPARENCYDISPLAY is set to 1?
Active Member
dshKSS
Message 6 of 6 (164 Views)
09-16-2013 01:07 AM in reply to: ow
That was it, so simple, thanks!
You are not logged in.
Ask the Community
