ObjectARX
To create independent exe file
3 REPLIES 3
cad_sudhir
200 Views, 3 Replies
I am trying to create exe file with MFC using VC++(6.0)
without arx (small dialog based application). Need help on samples/Tech notes
thanks
sudhir
3 REPLIES 3
in reply to: cad_sudhir
Hi Sudhir,
If your question is that you want to learn to use
MFC (i.e. not AutoCAD/ObjectARX related at all) then this is not the best forum
to use. Your best bet is to buy a good MFC book. Any decent beginners book will
tell you how to create an MFC dialog-based app. Or you could try the samples on
somewhere like
href="http://www.codeguru.com">www.codeguru.com
If you are interested in MFC within an ARX
application, then there are a number of MFC samples contained in the samples
folder of the ObjectARX installation. This is a good starting point (as is the
ObjectARX Developers Guide). Note that to use MFC within AutoCAD, you do need to
create an ARX application.
If you want to modify a DWG file without AutoCAD
installed on your machine, then you should investigate the ObjectDBX Application
Development Framework (
href="http://www.autodesk.com/objectdbx">www.autodesk.com/objectdbx
Cheers,
Stephen Preston
Developer Consulting Group
I
without arx (small
thanks
sudhir
cad_sudhir
Hi Stephen ,
thanks for reply
I am trying to read/create dwg file without autocad enviroment. (but with ObjectARx lab.)
(not using .arx files). I am seaching some samples for it but didn't get. Will U pls give some sanples for ObjectDBX ?
will really help me
sudhir
You will need to purchase a license of ObjectDBX from Autodesk to read/write
DWG files.
Use the contact information on the page below:
http://www3.autodesk.com/adsk/index/0,,770257-123112,00.html
"cad_sudhir" wrote in message
news:f090aac.1@WebX.maYIadrTaRb...
> Hi Stephen ,
> thanks for reply
ObjectARx lab.)
> will really help me
> Thanks
> sudhir
”Boost
