ObjectARX
Section View Pattern/Hatch Between Corridor and OG EG
2 REPLIES 2
Wang_Hongtao
490 Views, 2 Replies
      When we use autocad command "BHATCH", it will show a dialog and give the preview of the pattern currently used. My question is: Is there any way to implement previewing the pattern in a dialog of ourself? And linetype is like that also.
      thanks!
2 REPLIES 2
Balaji_Ram
in reply to: Wang_Hongtao
Those AutoCAD dialogs cannot be reused by your plugin.
There are ActiveX controls that are part of ADN Utilities which you can embed in your dialog to show hatch and linetype preview.
These can be donwloaded here which should also work with AutoCAD 2015 :
http://adndevblog.typepad.com/autocad/2012/08/adn-autocad-utilities.html
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Wang_Hongtao
in reply to: Balaji_Ram
Thank you very much, Balaji!
Tags (1)
”Boost
