Hi David,
The path must be a database resident entity, otherwise extrudeAlongPath()
will fail. DevNote 37173 - Creating and modifying AcDb3dSolid objects (on
ADN website and PointA Customization Channel) includes some sample code for
using this function.
Cheers,
Stephen Preston
Developer Technical Services
"David Skiba" wrote in message
news:1D33D27959A9B9847431C4889A56FC81@in.WebX.maYIadrTaRb...
> Hi there,
> I have a big problem with the AcDb3dSolid memberfunktion :
extrudeAlongPath.
> My Application WORKS if I use solid->extrude(region,height,0.0)
> But when I use solid->extrudeAlongPath(region,path) AutoCAD crashes.
> So the Error has something to do with the "const AcDbCurve* path"
> virtual Acad::ErrorStatus extrudeAlongPath(const AcDbRegion* region,const
> AcDbCurve* path);
> region Input pointer to a region object
> path Input pointer to a curve object to extrude alongĀ“
> Here my code fragments:
> AcDbArc Arc;
> Arc.setNormal(AcGeVector3d(1.0,0.0,0.0));
> Arc.setCenter(AcGePoint3d(0,200,0));
> Arc.setStartAngle(PI2);
> Arc.setEndAngle(PI);
> Arc.setRadius(200);
> AcDbCurve* path=&Arc; // I think here is the Problem !
> AcDb3dSolid* solid = new AcDb3dSolid();
> // extrude the region
> ////////////////// extrude(region,200,0.0); WORKS
> solid->extrudeAlongPath(region,path); ////// ERROR
> pBlockTableRec->appendAcDbEntity(ObjId,solid);
> solid->close();
> Thank you
> David
