ObjectARX
Showing results forĀ
Did you mean:Ā
Problem with solid->extrudeAlongPath(region,path)
1 REPLY 1
247 Views, 1 Reply
Hi there,
I have a big problem with the AcDb3dSolid memberfunktion : extrudeAlongPath.
My Application WORKS if I use solid->extrude(region,height,0.0)
But when I use solid->extrudeAlongPath(region,path) AutoCAD crashes.
So the Error has something to do with the "const AcDbCurve* path"
virtual Acad::ErrorStatus extrudeAlongPath(const AcDbRegion* region,const
AcDbCurve* path);
region Input pointer to a region object
path Input pointer to a curve object to extrude alongĀ“
Here my code fragments:
AcDbArc Arc;
Arc.setNormal(AcGeVector3d(1.0,0.0,0.0));
Arc.setCenter(AcGePoint3d(0,200,0));
Arc.setStartAngle(PI2);
Arc.setEndAngle(PI);
Arc.setRadius(200);
AcDbCurve* path=&Arc; // I think here is the Problem !
AcDb3dSolid* solid = new AcDb3dSolid();
// extrude the region
////////////////// extrude(region,200,0.0); WORKS
solid->extrudeAlongPath(region,path); ////// ERROR
pBlockTableRec->appendAcDbEntity(ObjId,solid);
solid->close();
Thank you
David
1 REPLY 1
Hi David,
The path must be a database resident entity, otherwise extrudeAlongPath()
will fail. DevNote 37173 - Creating and modifying AcDb3dSolid objects (on
ADN website and PointA Customization Channel) includes some sample code for
using this function.
Cheers,
Stephen Preston
Developer Technical Services
"David Skiba" wrote in message
news:1D33D27959A9B9847431C4889A56FC81@in.WebX.maYIadrTaRb...
> Hi there,
extrudeAlongPath.
> AcDbCurve* path);
> AcDbArc Arc;
> Arc.setRadius(200);
> solid->close();
> Thank you
> David
ā€Boost
