ObjectARX
Member
Message 1 of 8 (419 Views)
Problem loading arx in AutoCAD 2012
419 Views, 7 Replies
01-03-2013 10:36 PM
I'm using Visual Studio 2012 and ObjectARX 2012. When I load arx in AutoCAD 2012, a messagebox will popup saying 'AutoCAD is attempting to load *.arx which is not compatible with AutoCAD. What do you want to do?'
If I choose to load it anyway, it all works. I just want to know how it can come to such an incompatibility.
The project is in Framework 4.0 and Toolset v90.
Thanks.
Valued Mentor
owenwengerd
Message 2 of 8 (408 Views)
Re: Problem loading arx in AutoCAD 2012
01-04-2013 07:40 AM in reply to: jingjiwuci
One common mistake is linking with the wrong C or MFC runtime library,
Owen Wengerd
ManuSoft
Member
Message 3 of 8 (383 Views)
01-09-2013 02:08 AM in reply to: owenwengerd
Thank you, Owen. But linking with other runtime library can make build unsuccessfully. The runtime library is Multi-threaded Dll. Is it OK? "AutoCAD 2012 targets the .NET Framework 4.0, which is the default target for new projects in Microsoft Visual Studio 2010. No additional steps are required to test or debug an application in AutoCAD 2012". I found the statement in arxdev.chm. Then how it can come to such an incompatibility. I'm using Visual Studio 2010 and ObjectARX 2012. The project is in Framework 4.0 and Toolset v100.
Moderator
Alexander.Rivilis
Message 4 of 8 (376 Views)
01-09-2013 04:11 AM in reply to: jingjiwuci
1. >> I'm using Visual Studio 2012 and ObjectARX 2012... The project is in Framework 4.0 and Toolset v90.
2. >> I'm using Visual Studio 2010 and ObjectARX 2012. The project is in Framework 4.0 and Toolset v100.
Question: So which version of VS and Toolset do you use?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Member
Message 5 of 8 (363 Views)
01-09-2013 06:54 PM in reply to: Alexander.Rivilis
The second one.
Valued Mentor
owenwengerd
Message 6 of 8 (360 Views)
01-09-2013 07:22 PM in reply to: jingjiwuci
ObjectARX 2012 requires toolset v90, not v100.
Owen Wengerd
ManuSoft
Member
Message 7 of 8 (352 Views)
01-09-2013 10:55 PM in reply to: jingjiwuci
Thank you, Owen. You are right. Actually, I used toolset v100 because of not having VS 2008 installed.
Thank you, Alex. I got the solution from your reply in another similar topic.
It seems I have to install VS 2008.
Moderator
Alexander.Rivilis
Message 8 of 8 (348 Views)
01-09-2013 11:02 PM in reply to: jingjiwuci
jingjiwuci wrote:
...It seems I have to install VS 2008...
 I should clarify: VS 2008 SP1
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
