Hi Kimi,
try this
ads_command(RTSTR, WBLOCK, RTSTR, filepath2, RTSTR, "", RT3DPOINT, pt,
RTENAME,ent,RTSTR, "",RTNONE);
by theway: in R2000 & up you should use acedCommand() function
although ads_command() is still working
Moshe
wrote in message news:5059335@discussion.autodesk.com...
Hi ,
I am using WBLOCK command in my ARX application.
I am using two forms of wblock command as explained below: ( I am facing
problem in second form)
1. Writing created block in a new file using WBLOCK command:
I have created a block and using WBLCOK command I am writing this block in a
new file. I am succeeding here.
Following is related code:
Char filepath[20] =C:\\Test.dwg;
ads_command(RTSTR, WBLOCK,RTSTR, filepath,RTSTR,blkname,RTNONE);
// blkname is name of block I have created
This is working fine.
2. Writing selected entities in a new file using WBLOCK command: (use of
base point option of wblock command)
I have created a circle and want to write this circle in a new drawing using
WBLOCK command:
I have used following code:
//// some code for circle creation
Char filepath2[20] =C:\\Test2.dwg;
ads_name ent;
ads_entlast(ent)
ads_point pt ={0,0,0};
filepath2,RTNONE,RT3DPOINT,pt,RTENAME,ent,RTNONE);
Here I am not able to write created circle in a new drawing:
Actually I am doing following steps programmatically:
1. WBLOCK command at prompt.
2. Give name of new drawing
3. Give base point
4. Give entity for writing
What is going wrong in my ads_command parameters?
Thanks in advance.
KIMI
