Hi Jerry,
Thanks for the analyse and agree with you.
Thanks the reason i'm using persistent reactor which derive from AcDbobject.
Thanks again.
Koh
"shichongdong" wrote in message
news:5062088@discussion.autodesk.com...
Hi Koh,
I guess that it's my ID (shichongdong) that exposes my nationality and you
maybe kow a little about China and Chinese:)
Yes, the CNY (spring festival) is coming soon. Thanks for your best wish
and wish you have a good luck in the new year.
Focus on the real topic. I'm afraid that override the AcDbObject's virtual
function is more reliable than the reactor's virtual function.
To implement the functionality in event handler, when you are trying to port
the custom object to another application, AcEditorReactor::endDeepClone need
to be implemented again while to implement in custom object module doesn't.
-Jerry
"Ah Koh" дÈëÏûÏ¢ÐÂÎÅ:5062046@discussion.autodesk.com...
Thanks Jerry, for giving me another alternatives........
Are you a Chinese?
Anyway, wishing you a Happy CNY.
Cheers.....
Koh
news:5060874@discussion.autodesk.com...
Another approach is to override the AcDbObject::deepClone virtual function
which will be called when copy happens.
In this virtual function, you can access the cloned object. Use
AcDbObject::reactors to get all the reactors ( transient and persist
reactor). Use acdbIsPersistentReactor to check whether the reactor is
persistent or not. You can delete the copied persistent reactor and set the
cloned object with the old persistent reactor.
-Jerry
"Michael Riley"
D¡ä¨¨????¡éD???:5060038@discussion.autodesk.com...
When your object is copied, you will receive endDeepClone notification. You
can implement a reactor for endDeepClone that removes the persistent reactor
from your copied object.
"Ah Koh" wrote in message news:5058053@discussion.autodesk.com...
Hello World,
I understand that when we copy an object, any persistent reactors attached
to the object are copied as well.
Is there anyway to remove the copied objects' persistent reactor?
Thanks in advance.
Koh
