I to all,
I builded a simple dll arx with vs2010 (vc100), but when i load it from
APPLOAD acad2012 cmd, a window incompatibility msg appear 😮 !
Why ?! If I push the ok button, autocad load the arx correctly and all works ....
Is it possible to avoid the msg window ? Must I use vc90 ?
Best Regards
Leonard
Solved by owenwengerd. Go to Solution.
