ObjectArx 2014 wizard failed to create project in visual studio 2012?
Who can solve it?
I would simply load one of the sample ObjectARX VS projects and update it to your needs.
Same is happening to me. When I load new project it tells me loading failed. I uninstalled it and installed it again telling it the objectARX SDK folder and autocad 2014 folder. But still tells me loading failed.
like when i use the sample projects would it be ok? like would it be the same as creating new project?
Because ObjectARXWizards2014.msi doesnot run under the administrator permissions, many things do not take place in the installation. you can build a install.bat, and input" msiexec /i the path of ObjectARXWizards2014.msi", then run the install.bat under the administrator permissions.I have got it.
Your suggestion worked well. I uninstalled wizard 2014 and deleted all folders, then I installed wizard 2014 using a bat file as you said and it worked. My bat file has just two lines:
@echo off
msiexec /i “C:\ObjectARX-wizard-2014\ObjectARXWizards2014.msi”
Thanks for your input.
Racso.
