ObjectARX
ObjectArx 2014 wizard failed to create project in visual studio 2012
5 REPLIES 5
dnawujun
3681 Views, 5 Replies
ObjectArx 2014 wizard failed to create project in visual studio 2012?
Who can solve it?
5 REPLIES 5
fenton.webb
in reply to: dnawujun
I would simply load one of the sample ObjectARX VS projects and update it to your needs.
Fenton Webb
AutoCAD Engineering
kiyabole
in reply to: fenton.webb
Same is happening to me. When I load new project it tells me loading failed. I uninstalled it and installed it again telling it the objectARX SDK folder and autocad 2014 folder. But still tells me loading failed.
Kiya Chemeda
Civil 3D 2013
HP Pavilion dv6 cor i7
16GB RAM
windows 8
kiyabole
like when i use the sample projects would it be ok? like would it be the same as creating new project?
Kiya Chemeda
Civil 3D 2013
16GB RAM
windows 8
yexb69
Because ObjectARXWizards2014.msi doesnot  run under the administrator permissions, many things do not take place in the installation. you can build a install.bat, and input" msiexec /i the path of ObjectARXWizards2014.msi", then run the install.bat under the administrator permissions.I have got it.
racsoapres
in reply to: yexb69
yexb69:
Your suggestion worked well. I uninstalled wizard 2014 and deleted all folders, then I installed wizard 2014 using a bat file as you said and it worked. My bat file has just two lines:
@echo off
msiexec /i “C:\ObjectARX-wizard-2014\ObjectARXWizards2014.msi”
Thanks for your input.
Racso.
”Boost
