ObjectARX
Distinguished Contributor
Message 1 of 3 (479 Views)
ObjectARX Wizard 2012 on VS 2010
479 Views, 2 Replies
09-06-2012 11:12 AM
I'm getting an error during the creation of a new C++ project in VS 2010 using the ARX Wizard 2012
--------------------------- Microsoft Visual Studio ---------------------------
Specified argument was out of the range of valid values.
Parameter name: value
--------------------------- OK   ---------------------------
Then the project is not built. Has anyone else seen this?
ADN Support Specialist
Virupaksha.aithal
Message 2 of 3 (448 Views)
Re: ObjectARX Wizard 2012 on VS 2010
09-10-2012 11:19 PM in reply to: odoshi
Hi
Are you creating mixed managed project? If yes, then try below step
Edit the following file like below
C:\Program Files (x86)\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxAppWiz\Scripts\1033\default.js
Line #122
Change
config.ManagedExtensions =bDotNetModule ;
into
config.ManagedExtensions =(bDotNetModule == 'True') ;
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Message 3 of 3 (431 Views)
09-11-2012 06:01 PM in reply to: Virupaksha.aithal
Yes, it was a mixed managed project. That fixed it.
Thank you!
You are not logged in.
Ask the Community
