I'm not sure what's the purpose of the three DLL files lies in the SDK's
"inc" folder. The question depends on whether your application need these
DLLs or not.
1. If your application doesn't need these DLLs, just ignore them.
2. If your application really needs these DLLs, things become a little
complicated. Because runing your appliction needs these DLLs, so your
application need to know where to load these DLLs, which can be implemented
in serveral approaches: put these DLLs in the same folder as your
application; put these DLLs in the system DLLs folder, for example :
C:\windows\system32\ ; add the DLLs file to the "PATH" system varible. All
these approaches do is to let OS know where to load the needed DLLs. When
you ship your application, you need do the samliar thing to make your
application running normally.
-Jerry
"Nemorarius" дÈëÏûÏ¢ÐÂÎÅ:5059485@discussion.autodesk.com...
I've just downloaded the ObjectARX SDK (Arx_All.exe) from AutoDesk. I've
unzipped the file and found three DLLs in the 'inc' directory.
Question is, can I leave them where they are and add a reference to them in
my VS2005 projects, or should I copy them to some specific location?
When I install my application on a user's system, do I have to install these
DLL's in the same directory as my app, or do these belong in the GAC ?
Thanks in advance,
Anatolius Nemorarius
