ObjectARX
ObjectARX 2013 libraries
4 REPLIES 4
856 Views, 4 Replies
I am new to programming and I have been given a work in which I am required to update a project (made in Visual studio 2006 using ObjectARX 2006) and make it to run in Visual studio 2010 ( using ObjectARX / Autocad 2013). When I try to run the program I get this error :
LINK : fatal error LNK1104: cannot open file 'achapi.lib'
I was getting several more alike errors related to acdb16.lib, and other .lib files. When I searched for the files I found out a similar acdb19.lib  files (which I thought was an updated version of acdb16.lib and similar .lib files ) and now I am only getting error related to achapi.lib and that file is not there in the library files in ObjectARX 2013.
I wanted to know is that .lib file is no more used in ObjectARX2013 or do I need to include some other library file which has the same commands as achapi16.dll ?
I am stuck at that error. Please help.
Thank you in advance.
Tags (1)
4 REPLIES 4
owenwengerd
If you are inexperienced with Visual Studio and/or C++, I'm afraid you have a very long road ahead of you. Migrating any reasonably complex application from ObjectARX 2006 to ObjectARX 2013 will require much more than changing a few library names. I think a good place to start would be the migration guide in the docs subdirectory of each ObjectARX SDK. If you have general questions about compiler and linker errors, I recommend posting those in a forum dedicated to such topics (e.g. stack overflow).
Owen Wengerd
ManuSoft
in reply to: owenwengerd
Well, I've changed a lot of things in the program and I am stuck in the
library files.
By saying that I am new to programming I meant that I am new to programming
in Autocad and I have done programming before in C++.
I wanted to know wether is an upgraded or replacable library file for
achpi.lib.
Thank you.
owenwengerd
I'm pretty sure that the functions in achapi16.lib are included in acdb18.lib, but that's just a guess.
Owen Wengerd
ManuSoft
Thank you for the help 🙂
I will include that library file and see if it works.
Thanks.
”Boost
