ObjectARX
Valued Contributor
mbujak
Message 1 of 4 (132 Views)
.Net MDI Aware
132 Views, 3 Replies
05-23-2012 08:32 AM
How do I make a .net application MDI aware. In ObjectArx, acrxRegisterAppMDIAware(...) is used. Is there an equivalent method in .Net? I am using VS 2010 for AutoCad 2012. Any ideas?
Mike
Distinguished Mentor
owenwengerd
Message 2 of 4 (129 Views)
Re: .Net MDI Aware
05-23-2012 09:34 AM in reply to: mbujak
All .NET applications are MDI aware, so there is no need to notify AutoCAD to that effect.
Owen Wengerd
ManuSoft
Valued Contributor
mbujak
Message 3 of 4 (127 Views)
Re: .Net MDI Aware
05-23-2012 09:53 AM in reply to: owenwengerd
Thanks Owen. After you have replied, I thought it must be something else so I checked the SDI setting in Autocad and it was set to (1). I set it manually to (0) and all works fine. Is there a way to set this variable value in .net to ensure MDI awareness?
Mike B
owenwengerd
Message 4 of 4 (123 Views)
Re: .Net MDI Aware
05-23-2012 10:38 AM in reply to: mbujak
You can add code to your application that checks SDI at load time and refuses to run when SDI is set to 1, but you can't (and shouldn't even if you could) reliably switch SDI mode.
Owen Wengerd
ManuSoft
You are not logged in.
Ask the Community
