ObjectARX
Migration from 2013 to 2014
2 REPLIES 2
latoge
320 Views, 2 Replies
I get this error message when I try to run one of my tool (made for Civil 3D 2013) in Civil 3D 2014 :
System.MissingMethodException: Method missing : 'Void Autodesk.AECC.Interop.UiLand.IAeccApplication.Init(Autodesk.AutoCAD.Interop.AcadApplication)'.
Here are the reference I have in my project, all from ObjectARX 2013 :
Autodesk.AEC.Interop.Base
Autodesk.AEC.Interop.UIBase
Autodesk.AEC.Interop.Land
Autodesk.AEC.Interop.UILand
Autodesk.AEC.Interop.Common
I am using Visual Studio 2010, .Net Framework 4.   I tried to change ObjectARX 2013 for ObjectARX 2014 but I just found Autodesk.AEC.Interop, not the other ?
It's my first migration and I'm not use with ObjectARX so I don't know what I need to do.
2 REPLIES 2
owenwengerd
in reply to: latoge
The ObjectARX API is C/C++. It looks like you are using the Managed .NET API. You should post in the .NET group where you're more likely to get help.
Owen Wengerd
ManuSoft
latoge
in reply to: owenwengerd
Done thanks.  How can this post can be delete ?
”Boost
