ObjectARX
IntersectWith XREF entities
4 REPLIES 4
damir_vidakovic
862 Views, 4 Replies
I'm trying to find intersections between current drawing entities, and attached XREF entities.
So far I have made a function that enumerates all curve entities in the current drawing +  XREF curve entities.
I'm using acedSSGet with :n and later acedSSNameX for iterating through nested entities, that is entities inside XREF.
So far so good, I got the objectIds, but when I try to call intersectWith, I get no intersection points, and intersectWith returns eOk.
This is my code, I do not know what else to try.
static void multi_select_nested_entity(AcDbObjectIdArray &iaElementsInXref)
	// switch on the multi selection of nested entities
	setAllowDuplicateSelection(curDoc(), true);
	curDoc()->inputPointManager()->turnOnSubentityWindowSelection();
	ads_name sset, eName;
	AcDbObjectId id;
	// in the mode "_:n"
	if (RTNORM == acedSSGet(L"_:n", NULL, NULL, NULL, sset))
		std::set<AcDbObjectId> setIds;
		acutPrintf(L"\n");
		long len = 0;
		acedSSLength(sset, &len);
		for (long i = 0; i < len; i++)
			resbuf *rb = NULL;
			//  ssnamex() returns all selected nested entities
			if (RTNORM == acedSSNameX(&rb, sset, i))
				resbuf *rbWalk = rb;
				while (NULL != rbWalk)
					if (RTENAME == rbWalk->restype)
						eName[0] = rbWalk->resval.rlname[0];
						eName[1] = rbWalk->resval.rlname[1];
							if (Acad::eOk == acdbGetObjectId(id, eName))
//							acutPrintf(L"Entity %d: %x",i,id.asOldId());
							AcDbEntity *pEnt;
								if (Acad::eOk ==acdbOpenObject(pEnt,id,AcDb::kForRead))
								if (pEnt->isKindOf(AcDbCurve::desc()))
									acutPrintf(L"From XREF: (%s)\n", pEnt->isA()->name());
										setIds.insert(id);
									pEnt->close();
							else
								acutPrintf(L"\nCouldn't open object");
						//rbWalk = NULL;
					//else
						rbWalk = rbWalk->rbnext;
				acutRelRb(rb);
		acedSSFree(sset);
		set<AcDbObjectId>::iterator it;
			for (it = setIds.begin(); it != setIds.end(); ++it)
			iaElementsInXref.append(*it);
		// swtich off
	setAllowDuplicateSelection(curDoc(), false);
	curDoc()->inputPointManager()->turnOffSubentityWindowSelection();
// - ARSXTestXrefIntersect.test command (do not rename)
static void ARSXTestXrefIntersecttest(void)
	AcDbObjectIdArray iaElementsInXref;
	//find all entities
	multi_select_nested_entity(iaElementsInXref);
	for (int i=0; i < iaElementsInXref.length(); i++)
		AcDbEntity *ptrEntA;
		if (acdbOpenAcDbEntity(ptrEntA, iaElementsInXref[i], AcDb::kForRead)==eOk)
			for (int j = i + 1; j < iaElementsInXref.length(); j++)
				AcDbEntity *ptrEntB;
				if (acdbOpenAcDbEntity(ptrEntB, iaElementsInXref[j], AcDb::kForRead)==eOk)
					AcGePoint3dArray points;
					if (ptrEntA->intersectWith(ptrEntB, kOnBothOperands, points)==Acad::eOk)
						for (int k=0; k < points.length(); k++)
							//CARSCDraw::circle(points[k], k+1, AcGeVector3d(0,0,1));
							acutPrintf(L"\nIntersection found at x=%.4f, y=%.4f", points[k].x, points[k].y);
					ptrEntB->close();
			ptrEntA->close();
Damir Vidakovic
www.studioars.com
4 REPLIES 4
Xref entities (actually any entities in a block) are transformed by a AcDbBlockReference entity before being displayed. If you want to calculate an intersection, you need to account for that transformation.
Owen Wengerd
ManuSoft
Do you mean I have to transform the entities by transformation matrix before the intersectWith call?
Damir Vidakovic
www.studioars.com
Yes, that is it! If I move insert point of XREF to the 0,0 I get correct intersections. I believe I'll have to transform entities considering UCS from XREF to get correct results for every XREF.
Damir Vidakovic
www.studioars.com
If you're not worried about performance, you may be able to use AcDbBlockReference::explode() to create transformed copies of the entities.
Owen Wengerd
ManuSoft
”Boost
