I have a custom entity and I'd like to make it support command "addselected". Anyone knows which method I need to override?
Jonathan
Solved by maisoui. Go to Solution.
Solved by owenwengerd. Go to Solution.
Maybe this will help:
http://blog.jtbworld.com/2011/01/addselected-command-update.html
Once again your answer is clear and concise Owen. Thank you.
Too bad there's not a solution from the API, because it's not easy to manage the file AcSelCmdMap.xml of each of our customers.
