ObjectARX
Distinguished Contributor
maisoui
Message 1 of 3 (156 Views)
How to style correctly dimensions for DimDataused in Jigs and entities grips?
156 Views, 2 Replies
08-06-2013 04:48 AM
I'd like to create DimData (AcDbDimDataPtrArray) in my jig and my custom entity. I was able to reproduce the correct behaviour (like AutoCAD polyline), but it seems I have not initializing correctly the style of the dimension, because the result is not identical (look at the two pictures).
AutoCAD PLINE jig (during pan)
My jig  (during pan) - "errors" in red circle
Here is what I did:
I overrided the two following methods in my Jig (AcedJig) to provide DimData:
virtual AcDbDimDataPtrArray * dimData(const double dimScale);
virtual Acad::ErrorStatus setDimValue(const AcDbDimData * pDimData, const double dimValue);
In the first method, I create a simple AlignedDimension like this:
AcDbAlignedDimension * pDimension = new AcDbAlignedDimension;
pDimension->setDatabaseDefaults();
pDimension->setNormal(m_pEntity->normal());
pDimension->setElevation(m_pEntity->elevation());
pDimension->setDimscale(dimScale);
pDimension->setHorizontalRotation(0.);
AcDbDimData * pDimData = new AcDbDimData(pDimension);
pDimData->setDimFocal(true);
pDimData->setDimHideIfValueIsZero(true);
pDimData->setDimEditable(true);
m_dimData.append(pDimData);
return &m_dimData;
Maybe I need to call setDimensionStyle? But which style to use? I did not find any example in the Object ARX, any suggestions are welcomed.
Jonathan
Jonathan
ADN Support Specialist
fenton.webb
Message 2 of 3 (136 Views)
Re: How to style correctly dimensions for DimDataused in Jigs and entities grips
08-06-2013 05:15 PM in reply to: maisoui
are you missing the call to setDynamicDimension(true)?
Fenton Webb
Developer Technical Services
Autodesk Developer Network
maisoui
Message 3 of 3 (129 Views)
08-06-2013 11:07 PM in reply to: fenton.webb
Perfect! That is what I was looking for. I tried a lot of things by changing style properties, but I was in a wrong way.
Thank you very much for your answer.
Jonathan
You are not logged in.
Ask the Community
