ObjectARX
How to set a layout active?
3 REPLIES 3
chunyuran
876 Views, 3 Replies
AcDbLayoutManager::setCurrentLayoutId function.
This function makes the AcDbLayout object associated with the given AcDbObjectId the current layout in the active database.
Is there any way to set acitive layout in some unacive database?
3 REPLIES 3
Balaji_Ram
in reply to: chunyuran
You can try using the second parameter of the "setCurrentLayout" method which is a database pointer.
Here is a sample code :
<code>
Acad::ErrorStatus es = Acad::eOk;
AcDbDatabase *pDb = new AcDbDatabase (false, false);
pDb->readDwgFile (_T("C:\\Temp\\Test.dwg")) ;
AcApLayoutManager *pLayoutMngr =(AcApLayoutManager*)(acdbHostApplicationServices()->layoutManager());
pLayoutMngr->setCurrentLayout(ACRX_T("MyLayout"), pDb);
pDb->saveAs(_T("C:/Temp/Test1.dwg"));
delete pDb;
</code>
Balaji
Developer Technical Services
Autodesk Developer Network
chunyuran
in reply to: Balaji_Ram
Thanks Balaji.
The function
Acad::ErrorStatus setCurrentLayout(
    const ACHAR * newname,
    AcDbDatabase* pDb = NULL
is undocumented in AutoCAD 2008;
Is it available in AutoCAD 2008?
BTW: It works in AutoCAD 2012. Thanks again.
artc2
The database argument was added in AutoCAD 2010.
”Boost
