ObjectARX
How to draw a line with distance and vector ?
1 REPLY 1
Chaos0205
418 Views, 1 Reply
I was trying to create a command that based on 2 point(startpt,endpt) and 1 interget(distance) input, it will draw 2 line: 1 from 2 point and the other exactly a distance away from the 1st line. If anyone can help me to solve the problem in the title, this would be a big help . Thanks in advance!
1 REPLY 1
StephenPreston
in reply to: Chaos0205
Its probably easiest to draw one line and then call getOffsetCurves on that line to return the second line you can add to the database.
Cheers,
Stephen Preston
Autodesk Developer Network
”Boost
