ObjectARX
Distinguished Contributor
maisoui
Message 1 of 8 (362 Views)
How to display page setup dialog?
362 Views, 7 Replies
02-11-2013 04:59 AM
I'd like to launch the page setup dialog to directly modify properties for a particlar download. I tried the following code:
((AcApLayoutManager *)acdbHostApplicationServices()->layoutManager())->pageSetup(...);
It launches the dialog "Page Setup Manager" and it is necessary to click on button "Modify" to show page setup dialog. How to get rid of this click and directly show the second dialog?
Jonathan
Jonathan
ADN Support Specialist
fenton.webb
Message 2 of 8 (349 Views)
Re: How to display page setup dialog?
02-11-2013 05:44 PM in reply to: maisoui
I don't think it's possible - Isn't it just a case of using acedCommand() with the PLOT command?
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Moderator
Alexander.Rivilis
Message 3 of 8 (339 Views)
02-11-2013 10:40 PM in reply to: maisoui
It is look like possible only with Windows hook.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
maisoui
Message 4 of 8 (332 Views)
02-12-2013 01:05 AM in reply to: Alexander.Rivilis
Thank you for your answer. I don't understand how to use such a hook. Your idea is to manually simulate click on Modify button?
Jonathan
Moderator
Alexander.Rivilis
Message 5 of 8 (320 Views)
02-12-2013 03:17 AM in reply to: maisoui
Yes. Simple sample without any error checking and adopted for English and Russian localization of AutoCAD:
HHOOK hMsgBoxHook = NULL;
LRESULT CALLBACK CBTProc(int nCode, WPARAM wParam, LPARAM lParam)
    HWND hwnd;
    HWND hwndButton;
    if(nCode < 0)
        return CallNextHookEx(hMsgBoxHook, nCode, wParam, lParam);
    switch(nCode)
    case HCBT_CREATEWND:
            // Get handle to the message box!
            hwnd = (HWND)wParam;
            break;
    case HCBT_ACTIVATE:
            HWND hwndfirst = GetNextDlgTabItem(hwnd,NULL,FALSE);
            hwndButton = hwndfirst;
            do {
                CWnd *w = CWnd::FromHandle(hwndButton);
                CString name;
                if (w && w->IsKindOf(RUNTIME_CLASS(CButton))) {
                    w->GetWindowText(name);
                    // Name of button can be localized
                    if (name == _T("&Modify...") || name == _T("&Редактировать...")) {
                        UnhookWindowsHookEx(hMsgBoxHook); hMsgBoxHook = NULL;
                        w->SendMessage(WM_LBUTTONDOWN,0,0);
                        w->SendMessage(WM_LBUTTONUP,0,0);
                        break;
            } while ((hwndButton = GetNextDlgTabItem(hwnd,hwndButton,FALSE)) != NULL && hwndButton != hwndfirst);
static void ArxPageSetup(void)
    AcApLayoutManager *pLayMan = reinterpret_cast<AcApLayoutManager *>(acdbHostApplicationServices()->layoutManager());
    AcDbObjectId idlay = pLayMan->getActiveLayoutBTRId();
    hMsgBoxHook = ::SetWindowsHookEx(WH_CBT,CBTProc,NULL,GetCurrentThreadId());
    pLayMan->pageSetup(idlay,NULL,TRUE);
    if (hMsgBoxHook != NULL) UnhookWindowsHookEx(hMsgBoxHook);
Moderator
Alexander.Rivilis
Message 6 of 8 (319 Views)
02-12-2013 03:37 AM in reply to: Alexander.Rivilis
Another hook-function. Does not depend on the localization AutoCADTake it "as is", without any guarantees. :-)
// AutoCAD 2008...2013 has identical IDMODIFY number
#define IDMODIFY (4705)
    HWND hwnd;
    HWND hwndButton;
    if(nCode < 0)
    switch(nCode)
            break;
    case HCBT_ACTIVATE:
            hwndButton = GetDlgItem(hwnd, IDMODIFY);
            if (hwndButton != NULL) {
                ::UnhookWindowsHookEx(hMsgBoxHook); hMsgBoxHook = NULL;
                ::SendMessage(hwndButton,WM_LBUTTONDOWN,0,0);
                ::SendMessage(hwndButton,WM_LBUTTONUP,0,0);
maisoui
Message 7 of 8 (309 Views)
02-12-2013 04:49 AM in reply to: Alexander.Rivilis
Your solution works like a charm. But I don't know if I will implement it in release version of my software, because it's not the most proper code. :smileyhappy:
Jonathan
Jonathan
Moderator
Alexander.Rivilis
Message 8 of 8 (305 Views)
02-12-2013 04:57 AM in reply to: maisoui
Jonathan
... but look like there is no another solution (not using hooks)...
You are not logged in.
Ask the Community
