ObjectARX
How to deactivate command in document contex?
5 REPLIES 5
297 Views, 5 Replies
Hi!
I want to use "New" AutoCAD functionality in ObjectARX. Well, I create a command:
void newDrawing()
static char pData[] = "acad.dwt";
AcApDocument* pDoc = acDocManager->curDocument();
if (pDoc)
acDocManager->executeInApplicationContext(
newInAppContex, (void *) pData);
void newInAppContex(void *pData)
if (acDocManager->isApplicationContext())
acDocManager->appContextNewDocument(
(const char *)pData);
acedRegCmds->addCommand("MY_GROUP", "cad_new", "cad_new", ACRX_CMD_MODAL, newDrawing);
newDrawing is my command, that I add into AutoCAD. Next I start AutoCAD and in contex of Drawing1 (by default) I write cad_new. New drawing with name Drawing2 creates as the result. Next I decide to close AutoCAD, but I receive a message that there is still active command on Drawing1. If I switch between drawing, no problem to close Application, but I want to do this by program. Does anybody knows how?
Thanks, Daniela.
5 REPLIES 5
did you try
acedPostCommand("CANCELCMD");
I'm sorry, but I can't understand you. I try to find acedPostCommand, but there is no such function in ObjectARX help. My compilation finished with error: "error C2065: 'acedPostCommand' : undeclared identifier".
I need of more explanation, please.
Regard, Daniela.
See knowledge base artical 17088 at
for how to invoke this undocumented command.
Also take a look a Owen's Autocad Exposed page
for pre-2000 undocumented functions.
Paul Kohut
I'm
I need of more
Regard, Daniela.
Sorry, but the problems still ocuured. I declare acedPostCommand function and use it before createing a new document. I make many examples: in reactors, out of reactors, but nothing changes. If I close AutoCAD application, I receive a message: "AutoCAD can't close because there is command still active. Please, complete the command and try again.". How can I remove this message?
(Ofcource the message doesn't persist if I switch to the first document and after that use Alt+F4).
Thanks in advance, Dani.
I find the way. If somebody has the same problem, let see ADN number 44759.
”Boost
