Hi! I made my custom entity derived from AcDbCurve and i appended to it one triangular extra grip point like on a spline entity. I created a grip menu which appears when the cursor hovers over the grip using AcDbMultiModesGripPE class. But I have to imitate whole behaviour of the spline extra grip, so i need to make a checked or unchecked menu to switch between some modes. Can you help me?
Sorry for the delay.
I do not find any way to include the check mark in the multi-mode grips.
I have contacted our engineering team on this and will update you.
Hi Balaji!
If I understand this question correctly, this grip of AcDbSpline is not multi-mode grip but usual grip. And its menu activated with mouse click.
Menu can be created with help of AcDbGripData&colon::rtClk method. ObjectARX SDK 2008 has sample \samples\entity\grip which can help.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Thanks Alexander
Yes, you are right. It does not appear to be multi-mode grip.
From what I heard from the engineering team, the multi-mode grips also do not have the option to set the check mark.
@Balaji_Ram wrote:
... From what I heard from the engineering team, the multi-mode grips also do not have the option to set the check mark...
I think that using Windows hooks (SetWindowsHookEx) to make it possible, but in any case it is rather difficult and is not relevant to the ObjectARX.
