There is a tricky problem, when AcDbEntity used, I want Operations(i.e Modify, Delete) delayed after My Custom Judge return yes, or stop this Operation.How can I do?
Thanks!
If its your custom entity, then you can control this yourself because you implement all the methods yourself. If its not your entity, then the Overrule API may give you what you want.
See the ObjectARX Developers Guide section "Overruling Common Functionality at Runtime".
