ObjectARX
Distinguished Contributor
maisoui
Message 1 of 5 (351 Views)
How replicate PLINE grip menu on my custom entity?
351 Views, 4 Replies
02-04-2013 11:41 PM
I'd like to replicate the PLINE grip menu on my custom entity : when grip is hovered, a menu is displayed (actions = Stretch Vertex, Add Vertex, Remove Vertex).
For now, I can display a context menu by:
  1. creating a AcDbGripData (in subMoveGripPointsAt method)
  2. Specifying a custom GripOperation (function ptr) for hover
  3. Creating a CMenu in my custom GripOperation function
  4. Displaying my menu like this :
    BOOL result = pPopup->TrackPopupMenu(TPM_LEFTALIGN | TPM_RIGHTBUTTON | TPM_NONOTIFY | TPM_RETURNCMD, p.x + 15, p.y + 20, AfxGetMainWnd());
    (where p is a POINT representing the current cursor location)
I don't know if this is the right way because the point of the grip is blue (as if it was warm), while for the PLINE it becomes orange (see the image above).
And I like to know how to begin move grip process? The PLINE menu launches the command GRIP_STRETCH. I tried to use the same command but I was unable to execute it with:
acedCommand(RTSTR, _T("_.grip_stretch"), RTENAME, pickSet, RTNONE);
Maybe someone can provide an example? All suggestions are welcomed.
Jonathan
Jonathan
ADN Support Specialist
fenton.webb
Message 2 of 5 (328 Views)
Re: How replicate PLINE grip menu on my custom entity?
02-11-2013 05:50 PM in reply to: maisoui
Check out the class AcDbMultiModesGripPE class in dbMultiModesGrip.h in the ObjectARX SDK
Fenton Webb
Developer Technical Services
Autodesk Developer Network
maisoui
Message 3 of 5 (313 Views)
02-12-2013 12:44 AM in reply to: fenton.webb
Thank you for your answer. It could be a good solution, but I'm using OARX 2010 and I guess AcDbMultiModesGripPE appeared in OARX 2012 or 2013. Is there another solution or it's only a new feature of next OARX?
Jonathan
Balaji_Ram
Message 4 of 5 (295 Views)
02-14-2013 07:05 AM in reply to: maisoui
The API for multi-functional grips was introduced in ObjectARX 2012 although AutoCAD had it as a feature in 2011.
Sorry, there is no way to get it using 2010 SDK.
Balaji
maisoui
Message 5 of 5 (293 Views)
02-14-2013 07:07 AM in reply to: Balaji_Ram
Ok. Thank you for your anwser. I was able to reproduce this feature with a little time and perseverance.
Jonathan
Jonathan
You are not logged in.
Ask the Community
