ObjectARX
How get the points from point cloud entity by loading the pcg file?
7 REPLIES 7
Message 1 of 8
1054 Views, 7 Replies
I had a look at the objectArx header files and I saw that there is a AcPointCloud.h file hinting at some Point cloud processing functions.
I want to get every point and its properties from the point cloud data,In order to data mining;
 I did try to follow the article here:http://forums.autodesk.com/t5/ObjectARX/Accessing-point-cloud-entity-loaded-from-a-pcg-file/td-p/343...
it is topic form xerion and owenwengerd;
but,When I access the points by
// init AcPcPointProcessor
AcPcPointProcessor* ptProc = new AcPcPointProcessor();
//IAcPcPointProcessor* iptProc=0;
Acad::ErrorStatus err = acdbProcessPointCloudData(pEnt, boundingBox, 100, ptProc);
AcPcPointFloat* pt = ptProc->buffer()->floatPoints();
It is always has an error in Memory?
what can 1 do? unless I am missing something?
I put all the code  below, I hope  xerion and owenwengerd give me a reply . or other one give me a reply?
 thanks;
7 REPLIES 7
Message 2 of 8
#include "AcPointCloud.h"
#include <vector>
using namespace std;
class ACDB_PORT PcDataBuffer:public IAcPcDataBuffer
public:
PcDataBuffer(void);
~PcDataBuffer(void);
///<summary>Indicate if the points are in single or double precision.</summary>
bool nativeDbl();
///<summary>Resize the buffer. This may be a destructive operation.</summary>
bool resize(DWORD size);
///<summary>Shrink the buffer without destroying its contents.</summary>
bool shrink(DWORD size);
/// <summary>Return the number of points in the buffer.</summary>
DWORD size() const;
/// <summary>Return a array of single precision points.
/// This may return NULL if the buffer is not single precision.</summary>
AcPcPointFloat* floatPoints ();
/// <summary>Return a array of double precision points.
/// This may return NULL if the buffer is not double precision.</summary>
AcPcPointDouble* doublePoints();
AcPcPointAttributes* pointAttributes();
/// <summary>Return a point in single precision.
/// This will work regardless of the native precision of the buffer.</summary>
bool floatPoint(DWORD ptIx, AcPcPointFloat& pt) const;
/// <summary>Return a point in double precision.
bool doublePoint (DWORD ptIx, AcPcPointDouble& pt) const;
/// <summary>Set a point in single precision.
bool setFloatPoint(DWORD ptIx, AcPcPointFloat& pt);
/// <summary>Set a point in double precision.
bool setDoublePoint (DWORD ptIx, AcPcPointDouble& pt);
/// <summary>Get the translation offset of the points.
/// This offset needs to be added to each point in order to get the
/// original location of the point in the point cloud</summary>
bool offset(double& x, double& y, double& z) const;
/// <summary>This transform needs to be applied to the points to
/// get the points in world space.</summary>
bool entityTransform(AcGeMatrix3d& matrix) const;
/// <summary>Copy the contents of the given buffer.</summary>
void copyFrom(IAcPcDataBuffer const & from);
public:
std::vector<AcPcPointDouble> AcPcPointDoubleArray;
std::vector<AcPcPointFloat> AcPcPointFloatArray;
std::vector<AcPcPointAttributes> AcPcPointAttributesArray;
#include "stdafx.h"
#include "AcPcDataBuffer.h"
PcDataBuffer::PcDataBuffer(void)
PcDataBuffer::~PcDataBuffer(void)
if (AcPcPointDoubleArray.size()>0)
AcPcPointDoubleArray.clear();
if (AcPcPointFloatArray.size()>0)
AcPcPointFloatArray.clear();
if (AcPcPointAttributesArray.size())
AcPcPointAttributesArray.clear();
bool PcDataBuffer::nativeDbl()
return true;
bool PcDataBuffer::resize(DWORD size)
try
this->AcPcPointDoubleArray.resize(size);
catch (...)
return false;
return true;
bool PcDataBuffer::shrink(DWORD size)
try
// just discard excess capacity
this->AcPcPointDoubleArray.shrink_to_fit();
catch (...)
return false;
return true;
DWORD PcDataBuffer::size() const
return (DWORD)this->AcPcPointDoubleArray.size();
AcPcPointFloat* PcDataBuffer::floatPoints ()
return &this->AcPcPointFloatArray[0];
AcPcPointDouble* PcDataBuffer::doublePoints()
return &this->AcPcPointDoubleArray[0];
AcPcPointAttributes* PcDataBuffer::pointAttributes()
return &this->AcPcPointAttributesArray[0];
bool PcDataBuffer::floatPoint(DWORD ptIx, AcPcPointFloat& pt) const
if (ptIx < this->AcPcPointDoubleArray.size())
pt = (AcPcPointFloat&)this->AcPcPointDoubleArray[ptIx];
return true;
return false;
bool PcDataBuffer::doublePoint (DWORD ptIx, AcPcPointDouble& pt) const
pt = this->AcPcPointDoubleArray[ptIx];
return true;
return false;
bool PcDataBuffer::setFloatPoint(DWORD ptIx, AcPcPointFloat& pt)
this->AcPcPointDoubleArray[ptIx] = (AcPcPointDouble&)pt;
return true;
return false;
bool PcDataBuffer::setDoublePoint (DWORD ptIx, AcPcPointDouble& pt)
this->AcPcPointDoubleArray[ptIx] = pt;
return true;
return true;
bool PcDataBuffer::offset(double& x, double& y, double& z) const
return true;
bool PcDataBuffer::entityTransform(AcGeMatrix3d& matrix) const
return true;
void PcDataBuffer::copyFrom(IAcPcDataBuffer const & from)
this->AcPcPointDoubleArray.clear();
AcPcPointDouble temp;
for (DWORD i = 0 ; i < from.size(); i++)
from.doublePoint(i,temp);
this->AcPcPointDoubleArray.push_back( temp );
Message 3 of 8
class ACDB_PORT AcPcPointFilter:public IAcPcPointFilter
public:
AcPcPointFilter(void);
~AcPcPointFilter(void);
void doFilter(const IAcPcDataBuffer& inBuffer, IAcPcDataBuffer& outBuffer);
#include "stdafx.h"
#include "AcPcPointFilter.h"
AcPcPointFilter::AcPcPointFilter(void)
AcPcPointFilter::~AcPcPointFilter(void)
void AcPcPointFilter::doFilter(const IAcPcDataBuffer& inBuffer, IAcPcDataBuffer& outBuffer)
Message 4 of 8
class ACDB_PORT AcPcPointProcessor:public IAcPcPointProcessor
public:
~AcPcPointProcessor();
/// <summary>Return true to cancel processing.</summary>
bool cancel();
bool setCancel(bool b) ;
/// <summary>Called to abort the process</summary>
void abort();
/// <summary>Called after the last call to ProcessPoints</summary>
void finished();
/// <summary>Process point in buffer. This will be called repeatedly with
/// new buffer contents until all points have been processed.</summary>
bool processPoints();
/// <summary>Filter, if available, to filter points.
/// Called before processPoints() on the next batch of points.</summary>
IAcPcPointFilter* filter();
/// <summary> Set Filter, to filter points.
void setFilter(IAcPcPointFilter* newfilter);
private:
bool bCancel;
IAcPcPointFilter* ptFilter;
#include "stdafx.h"
#include "AcPcPointProcessor.h"
AcPcPointProcessor::AcPcPointProcessor(void)
PcDataBuffer *buf =new PcDataBuffer();
this->setBuffer(buf);
this->bCancel = false;
this->ptFilter = NULL;
AcPcPointProcessor::~AcPcPointProcessor()
if (this->buffer())
delete this->buffer();
bool AcPcPointProcessor::cancel()
return false;
bool AcPcPointProcessor::setCancel(bool b)
this->bCancel = b;
return b;
void AcPcPointProcessor::abort()
void AcPcPointProcessor::finished()
DWORD size = this->buffer()->size();
bool AcPcPointProcessor::processPoints()
return true;
IAcPcPointFilter* AcPcPointProcessor::filter()
if (ptFilter)
return this->ptFilter;
else
return NULL;
void AcPcPointProcessor::setFilter(IAcPcPointFilter* newfilter)
this->ptFilter = newfilter;
Message 5 of 8
the above is what I came up with and how I implmented the classes derived from the abstract implementations.
 Here is my main function calls:
void CPointCloudExtract::OnBnClickedButton1()
// TODO: Add your control notification handler code here
//DoSomethingWithEnt callBack
#pragma region
/*AcDbBlockTable *pBlockTable;
acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable, AcDb::kForRead);
AcDbBlockTableIterator* pBlockIt;
Acad::ErrorStatus es = pBlockTable->newIterator(pBlockIt);
if(Acad::eOk != es)
pBlockTable->close();
return;
AcDbBlockTableRecord *pBlockTableRecord;
for(pBlockIt->start();!pBlockIt->done();pBlockIt->step())
es = pBlockIt->getRecord(pBlockTableRecord, AcDb::kForRead);
if(Acad::eOk == es)
AcDbBlockTableRecordIterator* pEntIt;
es = pBlockTableRecord->newIterator(pEntIt);
if(Acad::eOk == es)
for (pEntIt->start();!pEntIt->done();pEntIt->step())
AcDbEntity* pEnt;
es = pEntIt->getEntity(pEnt, AcDb::kForWrite);
AcDbObjectId objectid=pEnt->blockId();
AcRxClass* pRxPointCloud = (AcRxClass*)acrxClassDictionary->at(ACRX_T("AcDbPointCloud"));
if(pEnt->isKindOf(pRxPointCloud))
int i=0;
AcDbExtents boundBox;
pEnt->getGeomExtents(boundBox);
if (Acad::eOk == es)
pEnt->close();
delete pEntIt;
pBlockTableRecord->close();
delete pBlockIt;
pBlockTable->close();*/
#pragma endregion
AcGePoint3d ptmin(0,0,0);
AcGePoint3d ptmax(1000000000,1000000000,2000000);
const AcDbExtents boundingBox( ptmin, ptmax);
static const AcString className(L"AcDbPointCloud");
AcDbBlockTableRecordPointer pBlockRec(ACDB_MODEL_SPACE,acdbHostApplicationServices()->workingDatabase(),AcDb::kForRead);
if (Acad::eOk == pBlockRec.openStatus())
AcDbBlockTableRecordIterator* it = NULL;
if (Acad::eOk == pBlockRec->newIterator(it))
it->start();
while(!it->done())
AcDbObjectId entId;
it->getEntityId(entId);
// open for read should be sufficient in case you like to process point clouds
AcDbEntityPointer pEnt(entId,AcDb::kForRead);
if (Acad::eOk == pEnt.openStatus())
if(AcString(pEnt->isA()->name())==className)
// here you go with your point cloud entity
int k=0;
//DWORD size = buf->size();
//ptProc->finished();
//bool ttd=ptProc->processPoints();
//Acad::ErrorStatus err = acdbProcessPointCloudData(pEnt, boundingBox,100,ptProc);
//DWORD size=iptProc->buffer()->size();
//IAcPcDataBuffer* buf = ptProc->buffer();
it->step();
delete it;
Message 6 of 8
What am I doing wrong? Hope to be able to help me, thank
Message 7 of 8
owenwengerd
Please post inline code using the code formatting tags, and only the bare minumum required to describe your problem. What exactly is the problem? State it clearly and specifically, including complete error messages or error status results.
Owen Wengerd
ManuSoft
Message 8 of 8
in reply to: owenwengerd
 Owen Wengerd,
      thank you,I have solved the problem.
    I have a new problem。
for (int i=0;i<ptProc->m_pcDataBuffer.size();i++)
pcDataBuffer.push_back(ptProc->m_pcDataBuffer[i]);
Here, I was able to get all of the point cloud data from pcg file。All the data points inside m_pcDataBuffer, including x, y, z。
Now, how do I change the color of each point and displays a different color for each point in autoccad?
what can 1 do?
”Boost
