ObjectARX
How display string in OPM (property palette with COM wrapper)?
1 REPLY 1
maisoui
727 Views, 1 Reply
I'm trying to display a string in the property palette within a COM object (OPM wrapper). I tried a lot of codes, but cell remain empty. Here's my code:
idl:
[propget, id(1), helpstring("property name")] HRESULT name([out, retval] VARIANT *pVal);
wrapper header:
OPMPROP_ENTRY(0, 0x00001, PROPCAT_Misc, 0, 0, 0, _T(""), 0, 1, IID_NULL, IID_NULL, "")
STDMETHOD(get_name)(VARIANT * pVal);
wrapper implementation:
GetElementValue(...)
if(dispID == DISPID_PP_NAME)
        CComVariant var;
        get_name(&var);
        BSTR str(var.bstrVal);
        pVarOut->vt = VT_BSTR;
        pVarOut->bstrVal = str;
        return S_OK;
STDMETHODIMP get_name(VARIANT * pVal)
    try
        AcAxDocLock lock(m_objId);
        if(lock.lockStatus())
            return (E_ACCESSDENIED);
        AcDbObjectPointer<BcModelViewportEntity> pModelViewport(m_objId, AcDb::kForRead);
        if(pModelViewport.openStatus() != Acad::eOk)
            return E_ACCESSDENIED;
        CComBSTR str(L"HELLO WORLD");
        str.CopyTo(pVal);
    catch(const HRESULT hr)
        Error(_T("An error occurred. Check the input params."));
        return hr;
    return S_OK;
Does anybody have a solution? Any suggestions are welcomed.
Jonathan
Jonathan
1 REPLY 1
maisoui
in reply to: maisoui
Found a solution. You do not need to use a VARIANT but directly a BSTR and it works perfectly.
Jonathan
Jonathan
”Boost
