ObjectARX
How can I find out if a point is inside a polygon?
4 REPLIES 4
488 Views, 4 Replies
I want to know how you guys find out a point if it is inside a polygon and
that's not
since a sometime i found it from AND website but it's just allowed only for
MCAD
what i use with ARX
thanks for read and sorry for my fooling words
4 REPLIES 4
You should be used AcGeBoundBlock2d (or AcGeBoundBlock3d)class, that has cointains() method.
Halloo,
The AcGeBoundBlock2d solution dose not work for every polygon, especially if
it is not rectangle or box.
If you do have OMF you can use AecGeRing::pointInRing after you converted the
polyline to a ring.
If you don't have OMF then I think you need to create a function by your self.
Andrei
> that's not
> MCAD
> what i use with ARX
1. draw a ray from your point in any direction
2. count how many times does your ray intersect with edges of your polygon
2.1. if count is odd (1, 3, 5, 7, ...) then the point is inside polygon
2.2. if count is even or zero (0, 2, 4, 6, ...) the point is outside
polygon
"honesty man" wrote in message
news:D7EB38CA39FAC407C2A142FF8C0F1ABA@in.WebX.maYIadrTaRb...
> that's not
for
> MCAD
> what i use with ARX
See the discussion thread on 3/9/02 called "Point inside my
entity". There is a sample program that shows how to use the
intersectWith function of AcDbEntity.
Paul Kohut
> that's not
for
> MCAD
> what i use with ARX
”Boost
