ObjectARX
Display ICOs on Toolbars?
2 REPLIES 2
177 Views, 2 Replies
Dear All,
Can anyone help? I'm trying to build a toolbar for my ARX app that will display 15x16 BMP images under AutoCAD 2000-2002 and 16x16 32-bit ICO variants under AutoCAD 2004-2006. I just can't figure out how to work with the ICOs/how they should be managed. I have tried:
1. Adding the ico files to the DLL in the same way the BMPs work.
2. Copying the separate ICO into the installation folder of my application.
3. Changing the name of the icon in the DLL to be the toolbar identifier.
Nothing seems to work! Any help is be much appreciated.
James
2 REPLIES 2
jameswood wrote:
> Dear All,
> James
1. is the correct approach only you need to add the icons as RCDATA
instead of as icons. For more info-
http://www.cadwerx.net/Free/CxToolbarIcons.asp
Best regards,
Byron Blattel
CADwerx--Applications for AutoCAD
Autodesk Registered Developer
Contact Info @ http://www.cadwerx.net
Custom Programming Services - ObjectARX/C++/MFC/ASP/STL/ATL/ISAPI...
Actually you have to go to the Developers section and click on the
'AutoCAD 2004 Toolbar Icons' link.
Best regards,
Byron Blattel
”Boost
