ObjectARX
Convert ads_name to VLA-Object from C++ARX?
4 REPLIES 4
diagodose2009
698 Views, 4 Replies
Hello...
Title:  Convert ads_name to VLA-Object from C++ARX?
I  want a function convert "vlax_ename2vla_objectC"
The "vlax_ename2vla_objectC",will convert "ads_name" to "vla-object"
You replace the "????" with your source C++ARX.
I need only VisualC++ARX
I need one function ads_retVLA_object(rr);
The function "vlax_ename2vla_objectC" return value idem with llisp:
(type (vlax-ename->vla-object (car (entsel)))
Please help me...!
[source=vlisp]
(Defun vlax_ename2vla_objectL(arg1_as_RTENAME / rr)
  (setq g (type arg1_as_RTENAME))
  (setq rr (vlax-ename->vla_objectarg1_as_RTENAME )
rr)
[/source=vlisp]
[source=cpp]
Smiley Tongue
int
/*FCN*/vlax_ename2vla_objectC()
    struct resbuf *pArgs =acedGetArgs ();
    if(!pArgs)
      return acedRetNil();
     if(pArgs->restype != RTENAME)
    AcDbObjectId id;
    if(acdbGetObjectId(id,pArgs->resval.rlname) != Acad::eOk)
   ads_retVLA_object(VLA-OBJECT)
[/source=cpp]
[source=virtualC+lisp]
(Defun vlax_ename2vla_objectC2012(a008 / e rr g j)
/*c2s: rr=nil,
       g=(listp(e)&&(e!=nil))?dfn_ent_dxf_01(e):a008,
       e=(type(g)==quote(ENAME))?g:nil,
       j= (type(a008) == quote(VLA_OBJECT));
       if (e)
           rr=vlax.ename->vla_object(e);
       else
           { if (j) rr=a008;
                   else  alert("a008errC");
rr)
[/source=virtuaC+lisp]
4 REPLIES 4
Balaji_Ram
in reply to: diagodose2009
Have you tried using the "ObjectIdToObject" method in the IAcadDocument interface ?
This will provide you with a pointer to the COM Interface (Ex : IAcadCircle) for the ObjectId that you pass to it as parameter.
You can find it under <ObjectARX folder>\samples\com\AsdkMfcComSamp_dg\CAcadDocument.h.
Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
Hi, Balaji!
But how can return this pointer from arx to lisp? IMHO it is impossible.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Hi Alexander,
I am not sure if the developer wants to pass it over to Lisp, because in that case the "vlax-ename->vla-object" would get the vla-object.
I thought the developer wanted to get the COM object using an ObjectId using C++ alone and had provided the Lisp code as a demonstration of what he wanted to do.
Sorry, but I might be wrong in understanding the question.
Balaji
Hi, Balaji!
diagodose2009 try to develop lisp to arx compiler/converter. It is understandable on the questions which he regularly gives on this forum. That is why hi try to emulate (vlax-ename->vla-object) lisp-function with ObjectARX code.
Expert Elite Member
”Boost
