Hi all!
Is there a possibility ro send a command to AutoCAD (eg. using sendStringToExecute) but not having
this command added to the history of the last used commands?
Setting the echoString parameter to false does not influence this behaviour.
Thanks in advance
Markus
Solved by owenwengerd. Go to Solution.
Create a command with the ACRX_CMD_NOHISTORY flag, then run that command via sendStringToExecute().
Owen Wengerd
ManuSoft
