ObjectARX
loic.jourdan
368 Views, 3 Replies
C++/CLI
Is it possible to enable C++/CLI (new vc2005 syntax) in objectarx for postrio (beta2/3)?
Thank you
20-20 CAD / 20-20 Technologies
3 REPLIES 3
in reply to: loic.jourdan
You can use the ObjectARX Wizard to create a project using managed C++.
wrote in message news:5085354@discussion.autodesk.com...
postrio (beta2/3)?
Thank you
loic.jourdan
it doesn't allow me to use new syntax. The default setting for a project created by oarx wizard is /clr:oldSyntax. if I switch this setting to /clr, I have error messages about compiler settings conflict...
loic.jourdan
I found a solution but, because I'm novice in C++/CLI, I'd like to be sure it's safe.
In oarx wizard, I didn't check ".NET mixed managed code support", in project properties, I enabled CLR support (/clr, not /clr:oldsyntax) and I disabled any entry point support (to prevent msil code called from Dllmain: http://www.codeguru.com/cpp/w-p/dll/mixeddlls/article.php/c3643__1)
finally, I added references to acmgd and acdbmgd assemblies.
It seems to work but I'm not sure it's totally safe.
can anyone confirm it's ok?
”Boost
