ObjectARX
*Rizzo, Jon
Message 1 of 2 (47 Views)
Bizarre error message
47 Views, 1 Replies
07-31-2002 03:30 AM
I have an objectarx program in which I used VC++ to build wrapper classes
for the Land Desktop 3 type library. I defined two commands that both add
cogo points to the current project. In both commands, I use the following
code:
extern COleSafeArray sa;
extern IAeccApplication app;
IAeccProject project(app.GetActiveProject());
IAeccCogoPoints CogoPoints(project.GetCogoPoints());
IAeccCogoPoint cgPoint(CogoPoints.Add(sa, kCoordinateFormatXYZ));
Both commands work properly, with one small exception. In one of the two
commands, the last line causes the following message to appear on the
command prompt:
ARX_ERROR: eInvalidAdsName
Aside from this error message, the code does exactly what is expected.
Any idea where this error message is coming from or what it means??
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
*Rizzo, Jon
Message 2 of 2 (47 Views)
Re: Bizarre error message
07-31-2002 04:08 AM in reply to: *Rizzo, Jon
nevermind, I found the problem. Apparently you can't add cogo points to the
database if the model space block table record is already open for read.
"Jon Rizzo" wrote in message
news:77332BDD13524518900373A0EDDA28F2@in.WebX.maYIadrTaRb...
> code:
> command prompt:
> Jon Rizzo
You are not logged in.
Ask the Community
