I'd like to work ObjectARX 2011 wizards with VisualStudio 2008 sp1 and ObjectARX 2012 wizards with VisualStudio 2010, but when I install the 2012 version it uninstall the 2011 version. Then dissapear icons from VS2008 ACAD tool bar and project type wizards too.
It seem not work correctly in VS2008 when VS2010 is installed.
Is not it possible to have both version installed?
Thanks and regards
HI there,
No you cannot install both versions of the Wizard.
However, the 2012 version is backward compatible and should install for both VS208 and VS2010.
Maybe you could try to install it again? And hopefully it would appear in both VS versions you have installed...
I hope this helps.
Adam Nagy
Autodesk Developer Network
the third installation seems works fine, but I had to uninstall ArxWizard 2011 manually before install 2012 version.
Thanks and best regards
