the following code can modify the patterscale of an existing hatch, but the hatch dosen't change its outlook. why?
AcDbObjectId idHatch;
if (!Acad_Selection::SelEnt(idHatch,_T("Hatch")))
return;
AcDbObjectPointer<AcDbHatch> pHatch(idHatch,AcDb::kForWrite);
if (Acad::eOk != pHatch.openStatus())
return;
static int nTemp = 1;
Acad::ErrorStatus es = pHatch->setPatternScale(pHatch->patternScale()*(nTemp%2 == 0?2:0.5));
es = pHatch->evaluateHatch();
++nTemp;
Solved by Alexander.Rivilis. Go to Solution.
What es value?
Facebook | Twitter | LinkedIn
static void HatchScaleHalf(void) { ads_name en; ads_point p; if (acedEntSel(_T("\nSelect Hatch: "),en,p) == RTNORM) { AcDbObjectId eid; acdbGetObjectId(eid,en); AcDbObjectPointer<AcDbHatch> pHatch(eid,AcDb::kForWrite); Acad::ErrorStatus es = pHatch.openStatus(); if (es == Acad::eOk) { pHatch->setPatternScale(pHatch->patternScale()*0.5); pHatch->setPattern(pHatch->patternType(),pHatch->patternName()); pHatch->evaluateHatch(); } else if (es == Acad::eNotThatKindOfClass) { acutPrintf(_T("\nIt is not hatch!")); } } }
