Is there a way to keep the compass when we export an image or rendered image? I know I can show the XYZ axis but I find it more userfriendly to have the cardinal point. It must have an option to keep it, but I cannot find where!
Solved by lee.mullin. Go to Solution.
Unfortunately this is not possible, the compass is visible when using the OpenGL navigation, but not when using the Presenter engine to render.
If the compass is neccessary then depending on the quality you need you might be able to use a screenshot application such as Snagit to get a screenshot with the compass in view.
