Navisworks General
Active Member
tonori
Message 1 of 2 (360 Views)
opening .dgn file screen is black - no visible objects
360 Views, 1 Replies
08-28-2012 01:34 PM
When opening certain .dgn files the screen is black, no objects visible - but I can see all the levels of the model in the selection tree - how do I tell if it's a bad file or if there is something wrong with my visibility?
Employee
JeffH_ADSK
Message 2 of 2 (347 Views)
Re: opening .dgn file screen is black - no visible objects
08-29-2012 03:42 AM in reply to: tonori
Hi there,
The first thing to check would be the Scene Statistics for the imported file. Does that show geometry being converted & suitable nodes being added that correspond to solids in the model? If not, then there's no geometry being converted in your model. Otherwise there are a few things you can check.
I would recommend changing the background colour away from black (the option should be available on the Ribbon), or selecting items in the selection tree. The selected items should highlight with the default highlighting colour. A combination of these should indicate if anything is visible.
Two other things to check are whether the items are coming in as hidden (in which case you can just Unhide them) and whether your default view is for some reason facing away from the actual model.
If all of those fail, you should be able to Show Developer Properties under Interface/Developer in the Global Options (this may require the Advanced Global Options, accessed by pressing Shift whilst clicking on Options), and see if you have any Geometry properties present in the model, and if so, what they are. If none are present, your model has no geometry.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
