The first time I've seen this problem. Did a fresh install of Navisworks Review and Freedom 2010 on a user's workstation. When the user tries to open an .nwf file Navisworks crashes and he gets the standard Autodesk submission form. When the user opens an .nwd file everything is fine. All global options are set up correctly. This is the only user having this problem. Any suggestions?
Can you open the nwf file on another computer ?
Try creating a new NWF file on the computer that has the errror to see if it is depending on the nwf file or the installation
Thank you for the responses. But apparently the user was trying to open nwf files with Freedom, not Review. Lesson learned: Always double check the user first
