Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
missing layer in object explorer
1 REPLY 1
300 Views, 1 Reply
Why under the selection explorer, some layers are missing (no plus sign next to the DWG file) ?
The single way we found to fix it is :
1-      Using Autocad, open the DWG file
2-      Using Autocad, save the DWG file.
Tags (1)
1 REPLY 1
Lance.Coffey
If opening the DWG in AutoCAD and resaving it clears the issue, then the program that originally wrote the DWG may be related to this issue.
What program was the DWG file created in?
Also, if you create a new file from the same program (with multiple layers), do you see the same result?
Lance Coffey
Technical Support Specialist
Rail Community
