Show only
Search instead for
When you say "... model of a process plant...", what program was used?
---------------------------------- If you are going to fly by the seat of your pants, expect friction burns. "I don't know" is the beginning of knowledge, not the end.
Hi again. Today I found a suggestion in a similar thread "Missing objects (cylinders) from a DWF file" that I will try out; "disable parametric primitives", and see if this fixes my export issue.
There may be object enabler issues at work here. There probably is an issue converting whatever PDMS is using for custom objects (as opposed to AutoCAD solids) into DWF format.
Could you attach the problem file (original from CAD application & NWD please if possible) along with reproduction steps or send it to Autodesk support as an issue please? I can make no promises as to when the issue will be addressed, but a reproduction case would greatly help speed investigation.
