Is it possible to go to a particular point location in Navisworks. Can someone please let me know the procedure for the same
Also would the same thing possible if instead of a structure I have point clouds.
-Thanks
Edited by
Discussion_Admin
What I did once is the following
Open Navisworks Simulate
Go to a positon manually, use the viewcube to look in a specific direction, like Nord.
Save a Viewpoint and give it a name
Delete all other viewpoints
Export the Viewpoints.XML
Edit the Viewpoints.XML with a Plain ACSII editor.
Replace the name of the viewpoint and the coordinates of the save viewpoint with those that you want to have
Save the XML and Load the viewpoints again in Navisworks
I was able to create viewpoints that way of the exact locations where the laserscanner was located,
so that the attached clouds were indeed very good visible.
How about right click at any margin area in the view, then click at VIEWPOINT->EDIT CURRENT VIEWPORT, and set the Position there?
