Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
clashes reduced
1 REPLY 1
tq1918
295 Views, 1 Reply
clashes reduced
Is there a way to make clash numbers reduced?
Example: two pieces of pipe with insulation cross: a clash is counted as insulation enters insulation 1.  Insulation enters the pipe 2. Insulation exits pipe 3.  Insulation exits insulation 4.
Instead of muddling through 1000 clashes I set my tolerance to 1” and work my way down from there.
This is not as accurate as I’d like.  Is there a way to make the items “more solid?”
1 REPLY 1
Patrick_Aps_9121
in reply to: tq1918
If the insulation is on a different layer than the pipe, you could de-select them in the tree of the clash manager. Then you only find the clashes between pipes. Clashes of insulation than can be solved when building..
Rail Community
