Navisworks General
Member
jianchengzou
Message 1 of 3 (265 Views)
Why Navisworks 2013 doesn't show one property while 2012 does?
265 Views, 2 Replies
08-13-2012 11:34 PM
My team working on interopreability program is affected by the problem as described below:
In Navisworks 2012 when it opens the ifc file exported from Tekla Structures, there is a GLOBALID property field in IFC tab; however in Navisworks 2013 that field doesn't exist anymore. Our previous wriiten code relies on that field to transfer information betwwen Tekla Structures and Navisworks. I have attached a screenshot for the question. Can anyone help me on this, thanks!
Jiancheng
New Member
kris.lengieza
Message 2 of 3 (171 Views)
Re: Why Navisworks 2013 doesn't show one property while 2012 does?
03-05-2013 05:20 AM in reply to: jianchengzou
Did anyone ever figure this out?
Valued Mentor
julianjameson8403
Message 3 of 3 (103 Views)
03-11-2013 08:26 AM in reply to: kris.lengieza
Have you tried changing the advanced options under the IFC file import to see if that changes the number of parameters available?
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
