Using Navisworks Manage 2014. I append a dwg. Zoom-All. My geometry shows up at the bottom right. There's apparently something in the dwg way up in the upper left. Open the dwg: Zoom Extents; Nothing there but what should be there. Purge DGN linetypes. Purge extended data (thanks for the exe Autodesk). Purge everything else. Wblock the whole drawing to a different filename. Back to Navis; append the newly-purged drawing and Zoom-All...same thing. My drawing is in the lower right corner. Navis is apparently seeing something in the upper left which I can't seem to purge out, even with a wblock.
No, I can't atach the offending dwg file; I wish I could. IP protection. If I did that I'd lose my job.
Any suggestions on finding what is pushing my drawing in Navisworks down to the bottom right when I zoom-all?
Thank you for any help.
Erik
