I have a model in mm, but when I start Walking, I have 2 issues:
1) the avatar is not appearing
2) I'm too small: as you can see when I come close to the van, the weel is a normal size of 665 mm,
but my horizon is only about 300mm above the floor, and this should be about 1,5 m
I'm using Manage 2011 to create the NWD and Freedom 2012.
Are there any options where the size of the avatar can be changed ?
Solved by Patrick_Aps_9121. Go to Solution.
Hi John,
your things were not the solution, but got me in the right direction
Clipping planes are Fixed at 0,125 and 500 (meters, i presume)
The avatar appears after I did a reset Default
but then changed the Height to 1m8, the Eye offest to 0,2m and the distance to 3m
and now we are back walking in a more realistic way.
