Users love to keep programs open "just incase I need it" but this ties up licenses. Simulate licenses are more expense than the now-retired Review so its not cost effective to purchase more every time we run out. The TIMEOUT feature in FlexLM licensing *really* needs to be implemented on these expensive products so those licenses not being actively used can be recovered for those that actually need them.
Yes, I realize this can be characterized as a management issue but I don't have time to constantly wander the office in jackboots making sure users are doing what they are supposed to...
Solved by dembkod. Go to Solution.
Hello dgorsman ,
This is a great suggestion. You should log this license functionality for our developers directly. Our enhancement request portal is here:
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
Already done. This has become even more important with the implementation of cascading licenses. Since we are running at near-total useage our single Manage license keeps cascading to support the "last" Simulate user.
Navisworks 2013 has been released with the TIMEOUT licensing feature included. The TIMEOUT will not operate if the application is launched via Automation, but in general use when Navisworks idles it should release the license as per usual rules.
Hope that helps,
Jeff
Hi Jeff.
We tried this, and it is not reclaiming the license after the period defined in the options file. Are there any limitations to how this works? We are going to try again with a 30 min (1800) inactivity timeout and also resetting the license service, but in the meantime any input is appreciated. We initially tested using this:
I can confirm that the timeout feature works for us but we use the TIMEOUTALL feature rather than specifying each product.
