Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Sweep on wall won't export from Revit
2 REPLIES 2
bbrown
590 Views, 2 Replies
I just received a Revit model from an architect that had a sweep at the top of the masonry walls for the coping. When I open the RVT in Navisworks or export a NWC from Revit, I only get the sweep and no wall. I removed the sweep and the wall comes through. I'm just posting this for anyone else that may stumble across the problem.
2 REPLIES 2
bbrown
in reply to: bbrown
sburke
in reply to: bbrown
I'm getting the exact same issue a wall with sweeps built in will not come in to the revit model!!!!!!
Autodesk you need to fix this!!!
Rail Community
